How to connect your audio amplifier device to your Fios remote control using remote codes
Your Fios remote control and set-top box are programmed when you receive them. Once your set-top box and TV are connected, use your Fios remote to program it to your TV.
With your TV turned on, press:
- Menu > Customer Support > Top Support Tools > Program Fios Remote, press OK and follow the prompts on your TV screen
Note: DRC800 Fios remote must be programmed using the steps in the user guide. Use the same steps if you need to reprogram your remotes.
To buy a new remote visit the Fios Equipment & Accessories Store.
Audio amplifier remote control codes
Find your audio amplifier remote control code(s) listed in alphabetical order by manufacturer below. The following codes can only be used with the Phillips P144 and Motorola DRC800 remote controls.
A – C
Manufacturer Codes Bose
0701
Curtis Mathes
0327
D – I
Manufacturer Codes Denon
3777
GE
0105
Harman Kardon
0919
J –N
Manufacturer Codes JBL
3781
JVC
0358
Left Coast
0919
Lexicon
3784
Marantz
0919, 3778
McIntosh
3785
O – R
Manufacturer Codes Optimus
0327
Parasound
3782
Philips
0919
Pioneer
0040, 0327, 3775
Polk Audio
0919
RCA
0327
S – Z
Manufacturer Codes Sony
0716
Soundesign
0105
Soundmatters
3783
Victor
0358
Wards
0105, 0040
Yamaha
0160, 0381, 3776, 3779, 3780
Remote Control User Guide
You can download your user guide below for additional information on your remote control. Select your user guide below:
1.Turn on the device you want to program your remote to
2.Press and hold the appropriate device button and press OK
3.Release both buttons and the device buttons will blink twice
4.Enter the remote code for the device, the device button will blink three times.
5.Point the remote at the device and press the Power button, and your device should turn off. This confirms it is programmed!
